Topic: 76mm C&L MAF (Read 1486 times) previous topic - next topic
76mm C&L MAF
Just wondering of someone here has a 76mm C&L MAF kicking around? Doesn't matter what sample tube it has as I've got the correct one for my combo. If you do let me know.
76mm C&L MAF
I don't have a C&L but I do have a nice Pro-m for #24 injectors........? PM me if interested
76mm C&L MAF
I'm actually looking for a C&L 76mm meter. I'm wanting to do some back to back comparisons with the 73mm one I already have.
76mm C&L MAF
Gotcha.........
76mm C&L MAF
I want to run the 73mm meter at the track and then swap it for the 76mm for the next run to see if there is any improvement. Just an experiment to see which one makes the car go faster or if there is any change at all. I just don't want to buy a brand new meter to try it ;).
76mm C&L MAF
Quote from: thunderjet302;431360
Post results.... I've thought about swapping to the 76 myself..
76mm C&L MAF
Quote from: V8Demon;431376
I will once I find one. I just don't want to buy one new.
76mm C&L MAF
No one has one eh?
76mm C&L MAF
Quote from: thunderjet302;431327
I just looked at an old one that I took off of my buddies mustang and it is a 76mm. He wants a $100 for it, let me know what you want to do and I will figure out the shipping.
Donnie
10 Second NA TBird
Fredericksburg Va
76mm C&L MAF
Quote from: 87 T-BIRD;432316
I may have a line on one. I'll let you know what's going on tomorrow :).
76mm C&L MAF
Quote from: thunderjet302;432331
Ok sounds good, it will also come with the pipe that goes to the throttle body.:D
Donnie
10 Second NA TBird
Fredericksburg Va
76mm C&L MAF
Quote from: 87 T-BIRD;432333
PMed you.
76mm C&L MAF
Checked it and sent you one back.
Quote from: thunderjet302;432335
PMed you.
Donnie
10 Second NA TBird
Fredericksburg Va
76mm C&L MAF
This can be taken down. I've got one now. Thanks.
