Topic: hello i am new with a 95 xr7 (Read 1276 times) previous topic - next topic
95 XR7--  I am looking for the exterior courtesy light covers , they fit between the quarter window and the metal molding at the door. I am unfamiliar with the different body styles and options for a cougar and want to know where I need to look for more information.
  would it be worth it to get a factory manual?. What i have now is a Chilton 83-97 t-b and cougar. I have worked on cars for over 40 yrs and dont have a problem buying a quality reference book, up until now i have stayed with GM-MOPAR-VOLVO-BMW and have no good info for this car. any help?
                                                Thanks Rick M
Do you mean an "85 XR-7?
thanks for the response "vinniebird" I am sure I have a 1995 XR7,4.6L,4R70W transmission w/ OD. roof is 1/2 vinyl and the ext. lights are between the trim strip that runs from the right door pillar over to the left door pillar. The lights are between that trim and the 1/4 window
Yeah, this is the wrong forum for you, you have a MN-12, this forum is for the Fox Chassis (1980-1988) cars.
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
The opera lamps you have are aftermarket. I don't know of any suppliers but generic opera lamps are plentiful on eBay. Should just need to measure yours and compare the dimensions to the one you find. Hope that helps.
Welcome!  While you are certainly welcome to hang out here, you will find much more info on an MN12 site as mentioned.  I recommend the TCCOA forums at http://forums.tccoa.com/
Quote from: rick m;431034
                                                Thanks Rick M
Try infiniteinnovations.com or E&G Classics.
opera lamps....sounds like he has a Bostonian edition...
