Topic: Question about 87's (Read 4418 times) previous topic - next topic
Question about 87's
Yeah, my 86 was factory console with a colum shift. I'm pretty sure its a gs, base cluster and only power windows and mirrors. manual seats and not much else. not even power door locks.
Question about 87's
This 87 Ranger I have now is an XLT, it has cruise and tilt, nearly unheard of options with a 4 cyl 5 speed!
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Question about 87's
Ahhhh, the AOD shuffle. Good times but very hard on the trans.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Question about 87's
Quote from: MY83T;430769
87/88 Thunderbird Sport - Cougar XR-7  5.0 with AOD 4 speed floor shift.
87/88 Thunderbird and Cougar LS  5.0 option, always column shift
I think that covers all the floor shift Thunderbird/Cougars from 83-88
Quote from: Haystack;430772
Interesting. I didn't think floor shifts were only 87-88 sport/xr7's.
Its rare to see a console in non floor shift cars, so I assumed the console was generally paired with a floor shift cars
My 88 LS 5.0 is floor shift.
My 87 LS 3.8 and 85 sage green GS 3.8 were full console cars.
Question about 87's
Quote from: MY83T;430789
86 Cougar was a Consolette unless you had a 5 speed or floor shift Auto Turbo Cougar XR-7  Odds are if you have a 5.0 with a console it was added after the fact.
I have to disagree here.  Both of the 86 Cougars (both GSs) I have had came with the full console with column shifters.  My current one was a 5.0 car.  The other one was a 3.8 that my father in law bought back in 1988 and I'm positive that is how it came from the factory.
Question about 87's
Quote from: Loaded87IROC;430832
Yes, this was a possibility. For 1985 & 86, the GS Cougar could be ordered with either the consolette or individual buckets (non-sport) with a full console (column shift).
The LS for '85/'86 however was only available with the consolette.
As far as I know the individual non-sport bucket seats with full console was a no-cost option during those two years. Again only available on GS only.
One of 1,246 built
Question about 87's
The console was optional, 1985-88, on all non-turbo/non-XR7/non-Sport models, except 1985-86 LS as BCA describes above.
It was actually part of the seating package which determined if the console was needed. If one ordered individual buckets, the console was added automatically.
The automatic floor shifter was also an option for 1987-88 non-TC/non-XR7/non-Sport models.
Any car without a floor shifter but with the console got a tray at the front of the console. Some cars' tray had a center divider, some were completely flat.
Question about 87's
Quote from: Haystack;430785
My 86 has a console and no floor shifter. they only had gave and ls those years with a 5.0. How do you tell which? The title only says cougar and it doesn't say ls anywhere on the car.
If the full console was factory installed, it would have to be a GS.
Three easy LS exterior identifiers over a GS ('85/'86)
Illuminated cat on the c-pillar
Bright rocker trim
Bright accents on the b-pillar trim
One of 1,246 built
Question about 87's
From what I can tell from the 88 Thunderbird order guide I've got it was possible to order a base Thunderbird with the console and floor shift (like a Sport/Turbo Coupe) but not a console and column shift. The 88 LX had to have a consolette and no floor shift as a "split bench" was standard with no other seating option available.
Question about 87's
IMO, that console-ette was the stupidest/most worthless thing on these cars! Ford really should have done a 60/40 or 50/50 split bench instead, of course, you wouldn't have been able to get power mirrors, windows or seats then, only power locks.
Question about 87's
Quote from: thunderjet302;430847
Interesting. The 88 Thunderbird order guide that I have doesn't allow for a full console in the base car or the LX.
For reference, mine is dated 2-29-88 (leap day! ;)).
One of 1,246 built
Question about 87's
Cougar experts, thanks for the correction, i was unaware of the GS/LS option.  More of a Tbird detail guy, i thought the options were the same for both lines.
Question about 87's
My 87 LX has the floor shift and Turbo seats..With this package was the suspension ant different? My car has almost every option minus pwr moon roof.
Quote from: thunderjet302;430791
Just to add more confusion:
My Thunderbird has a full length console removed from an 87 Cougar LS at the wreaking yard. The Cougar was a V6 AOD car which only had power windows, lock and mirrors. It had a column shifter with a full length console and the little tray in place of the shifter. It came from the factory like that. So it was apparently possible in 87 to order a Cougar with a full length console and a column shifter. Also in 87 the Thunderbird Sport didn't have the Turbo Coupe style sport seats but instead the base Thunderbird seats. In 87 the only way to get the Turbo Coupe style sport seats outside of a Turbo Coupe was to order them on a LX Thunderbird. That also got you a floor shift. However in 88 that option disappeared from the LX Thunderbird.
 S O L D
Question about 87's
The TB '88 dealer album I have claims the buckets & console were only avail on TC & Sport, not listed as a option on base or LX... Of course packages change, also doesn't mean it wasn't a printing error...
Question about 87's
Quote from: BCA;430854
I double checked mine and it's the same as yours. I read it wrong :hick:.
