Topic: Need TV cable. (Read 1425 times) previous topic - next topic
Need TV cable.
Does anyone have a TV cable for an 87/88 5.0? A friend of mine just picked up his first tbird and the part that clips onto the throttle body is broken. I don't want him to burn up his tranny.
Need TV cable.
A lokar is available, and they work better.
Need TV cable.
Isn't a Fox Mustang one physically the same?
Need TV cable.
Yes. I had a Stang cable on mine til I swapped to the T-5. They are on Ebay and check the Corral. Somebody over there always has one.
Need TV cable.
I was under the impression the way they connect to the throttle body was different from a mustang
Need TV cable.
86-88 5.0 are identical to 87-93 stangs. older cfi setups were also basically the same as the same year stangs.
Need TV cable.
cfi systems engaged the transmission by a drivers side TV rod which was sorta S shaped.
