Topic: Anyone use stock Mach 1 springs on a Thunderbird? (Read 7635 times) previous topic - next topic
I have a friend who may be giving me some Sn95 New Edge Mach 1 stock springs.  If anyone has used them on their 1987-1988 Bird, did it work out well?  What's the height difference if I were to use stock GT springs rather than stock Mach 1 springs?
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
Only if you have adjustable lca's in the back. It does drop the car quit a bit.
87 TC
Did you use LCAs for a New Edge or for a TBird?
'88 Thunderbird LX
CHE makes LCA's that are specific to our cars.  http://www.cheperformance.com/ProdList.asp?scat=30
Thank you!
'88 Thunderbird LX
I have the CHE adjustable on my Bird.
87 TC
I have a little negative camber on the front wheels using the mach springs. I don't know if I'll need MM caster camber plates to fix that. Yeah, the rear sits lower than the front but I'm running big and littles which compensates for it a little. Next set of tires I'm going to go to a little larger diameter in the rear tires and I think it will sit just right.
Are you running a bump steer kit?
87 TC
No bump steer kit yet. My future plans for the car may include corners so I may have to worry about steering!
Here's mine with SN-95 springs on it (all from a '99 Mustang)....
Vinnie, you have the CHE lca adjustables right? It looks like the rear sits higher than the front, which is the opposite of what I've got.
No, I have the basic CHE tubular control arms.
I'm leaning towards this height.
'88 Thunderbird LX
:iagree:
Vinnie, Did you retain the isolators on the Sport when you switched to Sn95 springs?
 S O L D
