Topic: AOD floor shifter (Read 2572 times) previous topic - next topic
AOD floor shifter
Does anyone know where I can get a floor shifter for AOD?  I have one for a TC but apparently that's not going to work (and it doesn't have a handle) .  I went to pic n pull and took an hour pulling one out of Cougar only to find out they wanted to charge me $75 for it (including $7 for the AOD cable bracket).  It wasn't in very good shape anyway so I left it there.  It would be nice to finish out my center console instead of having a big hole in it and get rid of the column shifter.
Thanks!
AOD floor shifter
It was pretty messed up or I would have.
AOD floor shifter
Blackbird 88 was kind enough to leave me message but I didn't check my email for a few weeks.  BB88 if you're still out there,  I replied to your PM.  Thanks.
AOD floor shifter
Hi Brook.  I just sent you a PM.  :)
William
AOD floor shifter
If you want this shifter Brook, I need an email address from you.
William
AOD floor shifter
The Turbo Coupe shifter is different than the 5.0 shifter.
AOD floor shifter
You're RIGHT!  Thanks for bringing that to my attention!
William
AOD floor shifter
They look about the same physically, but the shift detents are different.
AOD floor shifter
I had to swap the TC shifter out for one out of a Sport, so I should have remembered to look to see which style it was.  That mistake is on me.
William
AOD floor shifter
Yeah, AOD's have 6 positions, A4LD's have 7 positions, but a C3 also had 6, would one from a C3 work?
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
AOD floor shifter
I am not sure. I'd wait til you can get the right part for these cars.
AOD floor shifter
Yeah.  I have a TC shifter already.  Need the sport or Cougar AOD.  Bummer.
AOD floor shifter
im here in Simi Valley, south of you. rtf3774@yahoo.com we can work something out price wise for the shifter assembly if you want
