Topic: 84 t bird wiring nightmare (Read 1909 times) previous topic - next topic
Recently just traded my notchback for an 84 t bird with a 347 built trans and rear end. Well upon really going through every square inch of the car I noticed that the wiring was a nightmare. All hacked up and electrical tapped to hell. Well after countless hours of replacing all the wires and correctly running them to not look like a hack job I noticed the fuse box was missing many fuses. Is there a fuse diagram someone could show me or perhaps point me in the right direction?
Thank you in advance!
Tada
 http://www.coolcats.net/library/fusepanel.html
i think softtouch has an 84evtm or even an 83,,, wish i could have it for a couple days  to scan up on photobucket.
Ryan,
for your reference, in my links below and in Foe's signature as well, we have EVTM links that show all wiring diagrams for these cars... typically they are all the same in most areas but yet small changes would be unique to the year.
you can use ours to get you by, the fuse panels are the same design, but for 84, i cant assure you they are wire colored the same in our 87 and 88 evtm's.
if Foe can upload the scans,, that would help, meanwhile ill ping softtouch on his evtm's.
Fuse panel from the 84 EVTM.
