Topic: 5.0 so running rich (help!!!!!) (Read 13654 times) previous topic - next topic
Reply #60
34, bad egr. ignore this for now.
85 can op failure? No idea
10 doesn't show
18 spout input error. loss of spark
22 map/baro sensor out of range. id start by replacing or checking the map sensor.
21 ect out of test range.
34 egr again. ignore for now.
Map sensor is the biggest worry. replacing the dist might have helped your loss of spark. test or replace your map sensor and see what happends.
Reply #61
85 - CANP Circuit Failure
34 - EGR Valve Position/Pressure Feedback EGR Voltage Above Closed Limit
22 - Manifold Absolute Pressure/Barometric Pressure Sensor Out Of Self Test Range
21 - Engine Coolant Temperature (ECT) Sensor Out Of Self Test Range
18 - Loss Of Ignition Diagnostic Module Input To PCM/SPOUT Circuit Grounded
10 & 8 do not exist in EEC-IV that I am aware of.
The 21 is your biggest issue.  CanP is irrelevant for right now.  Put that at the bottom of the list.  The MAP code did not show while running so I would bet it's stored in continuous memory....It WILL put the ECU into FMEM (limp) mode though.... As will the code 34.  The code 34 on it's own will cause the ECU to plug in a "safe" value for EGR position and increase fuel a little bit.  Plenty of Fox Mustang guys report running around with no EGR and have zero issue.....
Do the KOER test again to make sure that 8 isn't in fact a repeat of 18.  That points to a possible faulty tach signal.  Test the ECT circuit.  Start with the sensor.  It's easiest to check and most likely your culprit.  The sensor is a thermistor that changes resistance as coolant temp. changes.
Reply #62
X
So this is nothing to worrier bout the car runs great with it unplugged an dies as soon as u plug it back in any ideas an thanks for the help with the codes would say I'll work on it today but its my sons 2nd birthday no work today
First car I owned an wish I wasnt so Young a Dumb
86-TBird 5.0 SO Pretty much original
GOT TO LOVE A FOUR EYE
81-F250- 7.5 460
73- closed camber heads w/ studs
Bored 30 over
528 lift voodoo can
1.73 roller rockers
PLAY TRUCK
11' KIA SORENTO (WIFES CAR)
96' SL2 SATREN 250000+ MILES DD
Reply #63
Do the Birds and Cougars have the salt and pepper shakers at the rear of the intake where the main EEC harness connects to the injector harness?  It sounds like all of these issues would be tied up in those connectors on my Coupe.  I had to tear those connectors apart and clean each connector by pulling it out of the plug.  Put it all back together with some dielectric grease and all the codes but the EGR went away which is due to me not running one.
Darren
Reply #64
That's no good....  What's your base timing at with the spout connector removed?  Aerocoupe, the sefi 5.0 has the salt & paper shakers.  It's worth a shot giving them a once over.... I'd verify correct timing, do the shakers, and re-check codes after....
Reply #65
Quote from: V8Demon;431374
Yeah timing could be waaay off......
Reply #66
The 10 is the separator between on demand and memory codes for KOEO.
He is using a code reader.
Reply #67
Don't forget, the spout turns off computer controlled ignition advanced. this also points to tfi/pip sensor issues.
Ect out of self test range could mean the car wasn't fully up to  operating temps.
My guess is still the same I had before. Map sensor. This should never show up in codes, cm or not.
In my opinion, the loss of spark, timing, and whatever is stopping it from running with spout out needs looked at first. my tbird runs fine right now with the egr not even plugged in, not even under the hood. I never even blocked off the vac line.
Reply #68
I'm using a code reader an I think 10 I think is cylinder one an I'll try to work on it this week sometime (I hope)
81-F250- 7.5 460
Bored 30 over
528 lift voodoo can
1.73 roller rockers
PLAY TRUCK
Reply #69
Didn't even think of that.  Second nature for me is to give the car a 10 minute run first.
Access to a Snap-on makes me forget.....I'll try not to again.  ;)
Quote from: thunderjet302;431380
I'm thinking this may be more of a PIP issue.....Worst case ECM.
Reply #70
It very well could be a PIP issue. He did mess with it.
Reply #71
If it was ecm its likely the sigrtn circuit would have fried. that would lose 90% of the sensors to the engine and likely wouldn't run at all with the spout out.
My opinion, verify positive timing setup, then verify spark/pip function. a new loaded dist was about $35 last time I bought one. swap in a good .fi module, clear codes and see what pops up. shouldn't take more then an hour in my opinion.
Overall, it should be a pretty simple fix as long as your able to trouble shoot components easily. its easy to get overwhelmed and over think things.
Reply #72
Here is a diy pip/tfi testing procedure. make sure your timing is set right and lets get ya back on the road.
 http://351winsor.com/joel/Ignition_Systems/tfi2.html
Reply #73
Reply #74
Sorry its been a few days I haven't had a whole lot of time lately with working an a 2 year old at home but as soon as I get a chance I'm planning on working on the car an I'll get back with y'all an thanks again for everyone's advice an wonderful help I can't thank everyone enough
81-F250- 7.5 460
Bored 30 over
528 lift voodoo can
1.73 roller rockers
PLAY TRUCK
