Topic: 5.0 so running rich (help!!!!!) (Read 13675 times) previous topic - next topic
Reply #45
and im over here thinking,, add a miniature adjustable bleed off valve inline with the map if you want a tad more power
and let the flames begin,,,
Major Tom,,,
can you be a tad more decent to stacks,,, seriously,, he's a good guy.  bad / good info is its own thing.  its not what your saying, its how your saying it.
oh well, just asking if you can lower the altitude.
Reply #46
Quote from: jcassity;429736
Major Tom,,,
You're askin Renzo not to be a ASS HOLE????
Bwahahah, yea right...
Reply #47
Quote from: TurboCoupe50;429728
In a nut shell, a small vac leak in SD EFI system will cause a lean condition, IF that leak is at the MAP sensor or line connected to it, system will be very rich as the MAP mostly determines the amount of load in these systems by monitoring vac level... Low vac at MAP = heavy load, system increases injector pulse... This is also why you can't run a long duration cam with these systems as vac will be low...
In a MAF system the MAP becomes a baro sensor(no vac connected to it), any leak past the MAF meter will cause a lean condition...
Of course the systems can adapt if something isn't grossly out of order...
As far as throwing parts at it, Ford says fix the FIRST code given and then retest, if there are additional codes address those after first is fixed... Probably 95% of the time this procedure works...
So didn't Haystack mention this in post #15 ?
As soon as Tom Renzo jumps into a thread and starts being a "BIG SHOT" that's when it get confusing and off track !!!
There is no need for his BS !!!
Reply #48
Ok Jay i got it!!!
Reply #49
We butt heads sometimes, but the point of this thread is to help the op, so lets get this thread back on track instead of arguing semantics. I really think that me and tom would get along well in real life, but its easy to act tough online and things are easily mis.construed until no one knows what's really going on.
Let us know when you can pull codes and exactly what comes up 86.
Reply #50
I'll try sometime this week I just had a death in the family so it my be a few days but as soon as I pull the codes I will let y'all know what I find
First car I owned an wish I wasnt so Young a Dumb
86-TBird 5.0 SO Pretty much original
GOT TO LOVE A FOUR EYE
81-F250- 7.5 460
73- closed camber heads w/ studs
Bored 30 over
528 lift voodoo can
1.73 roller rockers
PLAY TRUCK
11' KIA SORENTO (WIFES CAR)
96' SL2 SATREN 250000+ MILES DD
Reply #51
we are all sorry for your loss,,, I hope all goes as well as can be expected.
Reply #52
Thanks you all
Well I still haven't it to running the codes on the car pulled upper intake to replace valve cover gaskets an run out of time to put it back on I am going to work on it this Friday when I start my 7 day vacation from work But I also found out that the part I replaced on the distributor is most likely the problem but as soon as I get it put together I am running codes an letting ya know
81-F250- 7.5 460
Bored 30 over
528 lift voodoo can
1.73 roller rockers
PLAY TRUCK
Reply #53
Running codes takes less time then it took you to get tools out to pull your intake...
Reply #54
Well I could just do a koeo test some but somewhere along the lines of doing the test on a car with most sensors unplugged (upper intake is on work bench along with the dist) just don't sound like a real good way to do test but I'm just saying
81-F250- 7.5 460
Bored 30 over
528 lift voodoo can
1.73 roller rockers
PLAY TRUCK
Reply #55
Your time and money. I just hate replacing sensors and money on things that aren't broke.
Reply #56
Quote from: Haystack;430663
Quote from: 86TBIRD;430710
What Haystack meant is that it would have taken you less than 5 minutes to pull codes before you pulled your intake to replace parts willy nilly. It takes more than 5 minutes to pull the upper intake. A paper clip and you would have been all set: http://sbftech.com/index.php/topic,2471.0.html
Reply #57
The only reason I pulled the intake was to replace the valve cover gaskets because they were starting to leak not to replace ANY THING ELSE an I'm planing on putting it all back together this weekend to run test an go from there an thank you all for your advice y'all have been a great help
81-F250- 7.5 460
Bored 30 over
528 lift voodoo can
1.73 roller rockers
PLAY TRUCK
Reply #58
OK finally got codes
KOEO- 34,85,10,18,22
KOER- 8,21,34
I swapped out dist for a good one an the little black plug on the wireing for the dist I had it unplugged to retime the car an everything was running great then I plunged it back in an the car died an I had to unplug it to do the KOER test could that piece be the problem or is it a step in the right direction thanks for yall's help
81-F250- 7.5 460
Bored 30 over
528 lift voodoo can
1.73 roller rockers
PLAY TRUCK
Reply #59
Oldfuelinjection.com is down... gimme a minute and ill find a source for pulled codes for you.
