Topic: what parts (Read 3153 times) previous topic - next topic
what parts
what parts will interchange between a fox and SN95 Mustang and my 88 Turbo Coupe???
Re: what parts
Quote from: deggy67
SMART ASS ANSWER.... I know a guy with a '94 Stang 5.0 in a '85 TC...
Re: what parts
the link is very imformative but it did not have the exact info I was looking for. I would like to know if I can use any other strut beside the stock adjustable type on my 88 Turbo Coupe
Re: what parts
You actually cover a pretty broad range there....
Well, what do you mean by "interchange"?  Stuff that us a direct replacement, or stuff that is (easily) swappable?
Not much is a direct replacement.
My 83 Tbird though has (had) front spindles and brakes, front seats, axles, wheels from an SN-95.
Re: what parts
In short, yes you can.  I couldn't tell you exactly which part nubmer, but I know you can use different struts.  If not, TC's would be off the road, or people would be driving them around with bad struts.
Re: what parts
Yes...you can get by with any 87+ Mustang strut if you need to.  I've used both Fox and SN-95 struts on both lowered and stock height Tbirds/Cougars....
Re: what parts
Do I have to change spindles or anything else to use a Fox or SN95 strut? I need to replace what I have because with it set to Firm it rides worse than a 59 Caddy.
Re: what parts
Quote from: deggy67
Reread my post and look at the years listed.  I didn't mention swapping spindles did I ? ;)
Re: what parts
Quote from: deggy67
Is the firm light actually on??? Reason I ask is usually the switch contacts are dirty, not allowing the system to switch to firm. When the system is in soft(auto), there is almost no damping action and they float just like a '59 Caddy.
If the auto ride system is completely inoperative, you can remove the actuaters and there is a small pin in the top of the strut/shock that can be rotated. Every 1/4 turn changes from firm to soft...
Re: what parts
your the man chuck, as far as the light, it is on but I talked to the previous owner today and he said the they had already been replaced so no need o worry about an electrical problem. it is obvious that struts are worn out. I appreciat ethe help so far and I hope I won't annoy anyone with all the other questions I am sure I will have.
Re: what parts
