Topic: What would cause white valves? (Read 5200 times) previous topic - next topic
This is exactly what they look like the pictures not lying
I do believe that white is good or normal, but then again I spray paint for a living.
I know white on plugs is lean
I've heard clean burning or modern "lean burn" fuel causes it.
This is what the valves on the GT40Ps I had on my Thunderbird for 6K looked like after I pulled them (they were new when I bought them). The exhaust valves are lighter than the intake valves but not white.
It's running lean & TJ's is a little rich on three cylinders, the lighter valve being the desired color...
this motor came out of my oldest sons tbird,, we are breaking it down to the block.
it ran fine,, had oem HG's and good looking mains and rod bearings.
it was prob due to the stock fuel pump.
I wonder if the new E10/E15 is contributing to the white valves?
Quote from: TurboCoupe50;428049
Actually the lighter exhaust valve looked like the others till I got some gasket remover on it while cleaning the old head gasket off. You can see the far left side of the valve is a bit darker. Actually the car does run a tiny bit on the rich side. I'm going to try swapping MAFs in the spring to see if it leans it out a bit. Fuel pressure is 39 PSI with 24lb injectors and a 155lph Walbro in the tank.
Dumb ass me sold those heads in November 2012 (with 6-7K on them) for $300 locally. Two weeks later I bought a Mark VII. I also have a spare GT40 intake sitting around. Stupid, stupid, stupid.
Quote from: Thunder Chicken;428092
Maybe? I've been running that E10  in all my cars for years (all we have here) and the valves on the GT40Ps I pulled off my Thunderbird weren't that white. Thunderbird got 93 octane from the start with this engine though (reduce chance of knock with advanced timing).
How about red exhaust valves...?
Quote from: ZondaC12;428102
Fuel additives (like STP) contain chemicals that can turn exhaust valves red.
We have e10 here. Ive been running about 16° timing on my tbird with no detination.
Wide band monitoring would have put this in perspective. Normally exhaust valves should be light brown across the board. But not uncommon on a stock engine of OBD1  controlled to be a tinge on the white side.(white Not necessarily LEAN but close)Today it is mandatory to monitor A/F at all times. With today's fuels monitoring plug color is basically useless. To an extent when your A/F ratios are correct or near correct.
Here is how you fix it. One of my best tuners tuning one of my cars after a cam swap. Mark reads the A/F ratio after he makes adjustments. I maxed out my 42 LB injectors and had do change them out to 65 to get my DC correct
Quote from: thunderjet302;428133
I was told that by SOMEone at SOME point. Apparently the fuel around here has a witch's brew of additives then!
