Topic: Looking for this vacuum T (Read 1808 times) previous topic - next topic
So last night the brittle plastic that once made up this vacuum T finally broke...
I haven't found anything just by running the part number yet. I was wondering if anyone new of somewhere to get it from or something similar.
1988 Thunderbird Sport aka 'The Beater Bomb!'- Eibach Sportline Springs, Removed Silencer, Straight Pipe Exhaust
3G Alternator, Mustang 8.8", Thunderbird Sport 10" drums, 3.27 gears on a locker.
Any efi 5.0 mustang/tbird/cougar/Capri will have that. In a pinch you can use a vac tree from a 2.3 Stang
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Brand new.....
http://www.latemodelrestoration.com/item/LRS-9490A/86-93-Mustang-50L-Vacuum-Tree
Plastic parts such as these I've taken to using new or unused.  The heat cycles under your hood dry out the plastic and make it rather brittle.
also a sign of bad motor mounts. extend the hose to your new part, and test/replace your motor mounts if necessary.
I have built a new one with a metal pipe, a bunch of plastic vacuum fittings and some electrical tape to get me by a few weeks before. a few times pulled apart a ball point pen and stuck it in the vacuum from manifold to the map sensor, wrapped in electrical tape to get me home.
That's funny you need that. I was going through the shop and found one today. It's yours for $15 shipped.
Quote from: Haystack;427940
I read your post and thought of this:
Older cars can make us do creative things.
True. I saw an aftermarket piece made from anodozed tubing and screw in vacuum inserts. Nice stuff.
