Topic: 4r70w internals in an AOD (Read 8220 times) previous topic - next topic
I need to do a budget rebuild and need it done quick. I have read on here that the 4r70w internals are a direct bolt up, upgrade for the AOD. Is this true?
and if so, can i buy a 4r70w rebuild kit and put those internals in my AOD without needing to purchase anything else.
P.S- I have a B&M shift kit. would really like a VB but its a super tight budget build.
Thanks in advance!
A rebuild kit will get you gaskets, seals, clutches, bands and steels.  But for the hard-parts (stuff not meant to wear out), you'll need a 4R70 to get parts from.  Mine was cool, because I work in a Ford dealer and the auto trans guy had literally EVERYTHING under his bench.  The only thing I had to buy was a set of clutches and a front pump gasket.  Anybody else would have to have 1 of both trans'.  It's definitely a rewarding mod, though, and not many guys here have it.
thank you.
what is everyone's opinion on the all stock AOD with "epoxy mod" (i guess this is the equivelent to the 4r series "j-mod"?
I still have this and the 470 parts are in it.
http://www.foxtbirdcougarforums.com/showthread.php?19763-500-Hp-Aod
kitz kat, thank you but im on a super tight budget and that is too much for that budget. although it would be perfect if i had the cash...
No problem, just putting it  out there. It's a great buy for someone.
Quote from: 85cougar;427671
thank you.
All the epoxy mod does is change the shift patter on an AOD. It's not a shift kit/improver mod at all. Instead of the shift pattern being P/R/N/OD/D(3)/1 it becomes P/R/N/OD(3/4)/2/1. The epoxy mod allows you to shift the transmission manually from 1st, to 2nd, and finally to 3rd gear. You will lose the ability to lock out OD. I would recommend you only do the epoxy mod if you upgrade the OD band and servo to handle the extra abuse. The transmission in my Thunderbird has the epoxy mod but it also has a 2" OD band and an A+ OD servo.
Thank you for the insight thunderjet.... last question.
I'm pulling a 4r70w trans from the junkyard tomorrow. Is there any preference in them v6 vs v8, year to year, as far as using their internals in the 5.0 AOD?
V8. 5.4L Econoline if you can find one, most 5.4 trucks will have a 4R100, and you don't want any of that, but if you can find a 5.4L E van with a 4R70W, grab that shiznit, because it's got the most clutches and best servos.
I found a van with the triton motor..... thanks tfyk
i sure hope its a 70 because i already pulled it lol, the crossmember said "70w" on it. 2001 Van
There may have been one in the pan, I don't remember. I didn't take the pan with me. I want to say there was though
