Topic: Ah blown strut and tweaked CC plate lol suggestions please!! (Read 4181 times) previous topic - next topic
So I found out why my car bounces like a  on the highway and hits hard on the pot holes. About 5 months ago I had cut some SN95's front springs and also put in some lightly used Fox Body Tokico's. I also had MM CC plates from the previous owner. Got everything aligned and it was okay for a lil while. A few months ago it rode worse kinda felt like it was all over the road and I attributed that to not having a Bump Steer Kit. I get the thing on a lift yesterday and noticed my pass side strut is soaked in oil and also a slightly tweaked pushed up CC plate as well. So I want to fix it the right way for safety reasons obviously but I also want to know why the plate actually bent up so I can try to prevent it. I know I hit a few ugly pot holes in the past so maybe that's all it takes.
-So im thinking of buying actual lowering springs for a SN-95 but how much of a drop, for a v-6 or v-8, and at what rate ? (progressive or specific)
-I cant really afford Konis so any suggestions for a cheaper alternative for front struts?? And also should I get SN95's or Fox body struts..im pretty sure the length is the difference between the two.
1988 T.C.
88 Turbo Coupe 5 Speed..Full exhaust, K and N, Boost Controller
I would contact mm those plates should not bend
I did just email them about buying a single replacement plate and did mention that it bent. Im not the type of complain unless its a total piece of  and frankly im blaming either having cut springs or the terrible roads here. I was thinking about it and in a stock suspension setup when you fully compress the tire into the wheel well what stops it? The spring or strut?
FROM MM's site
Caster/Camber Plate Warranty
Maximum Motorsports provides a warranty on all MM Caster/Camber Plates against spherical bearing failure and plate bending. This warranty applies only to the original retail purchaser of genuine MM Caster/Camber Plates purchased after January 1, 2003; it does not apply to damage sustained in a crash. If the spherical bearing fails or the plate bends we will provide a replacement component for free.
To bad my car came with the MM CC plates and they never gave me any receipt for em so I have no clue when they were purchased.
Just thinking out loud here, but because the strut had no pressure in it and allowed it to bottom out very rapidly is why the plate bent. I could be wrong but I think in most cases the strut limits the travel, some struts will have a rubber bump stop at the top for just this reason. Normally they compress at a rate that the c/c plate or strut tower can handle.
Use the SN 95 frt struts, I am pretty sure they have more travel than earlier mustang struts.
Quote from: bodyman;427637
The only reason I was thinking they wouldn't work was because with the fact that the car is lowered it would cause issues with the strut bottoming out. Mainly because I thought the fox shocks were shorter than the SN95's. I think if end up getting sn95's ill get some monro struts or something cheap along those lines in case they blow out quickly for whatever.
those plates are designed for coil overs which puts all the weight of the front end on the plates
I really don't see how they would bend . But things happen
Dont underestimate the really deep shi*ty potholes here in CT lol. If you combine that with low pro 17's and a blown strut im guessing its a possibility lol.
Yea I could imagine
My dad bent a strut hitting a pot hole
Check out this guy lol
X
Holy $hit
That's way worse than I imagined
Your telling me..just saw it but who knows how long its been like that. Might explain why this thing is all over the road sometimes lol. After I fix everything im gonna get the bump steer kit as well.
I would sent that pic to mm just to see what they say
They gotta have a comment lol
I did a little while ago to see what they recommend I replace..who knows maybe they'll toss me a bone. Either way ill report back.
Yea you never know
