Topic: Trottle body and spacer (Read 1630 times) previous topic - next topic
looking for a decent trottle body and spacer for a new 5.0 build i am doing.
something better than stock
i wont haggle, just gathering parts for this project.
better then stock as in h.o.? I have a throttle body and egr spacer of an h.o. motor.
well,,  i think thats 55mm?
need to ask about the bore diameter on that PP intake im getting.
professional products edelbroke rip off should be 70mm.
Quote from: 88turbo;426657
I have one from an explorer, 65mm.
Pls sell if you can.....
i  just noticed the explorer upper is kinda "knecked" inward but its actually 73mm just an inch up into the bore.
Quote from: Haystack;426659
yeah,,, i hear ya!,,,good part is my cash is staying in the country.
even on masons build not a dime went to another countries stock exchange.
been wondering whats up with the PP intake tag saying made in USA.
Quote from: jcassity;426666
are you interested? I have no need for it.
yep, sure am...
sad part is i tossed out a couple stock TB's,, totally forgot to save the shaft to transition it over... oh well
I have a stock HO unit. No tps or iac. Cover the shipping and its yours
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
As a FYI: the opening on the stock Explorer GT40 upper is 68mm-70mm depending on how it was finished. I've measured 4 of them and one was 68mm, two were 69mm, and one was 70mm. All of them were off 96-97 Explorers. I have the one with a 70mm opening on my Thunderbird right now as I'm running a 70mm TB. You can open them up easy but since I had 4 laying around it was easier to just use the one with the correct opening.
check yours again,,
i was measureing about 1'' or so up inside the bore,, not the actual end of the bore.
i noticed the bore on the end where the spacer mounts kinda tapers inward a little.
Quote from: jandmmustangs;426708
thank you,, send me your addy on pm and i will get you a post office money order out monday.
Pm sent. Hopefully ya got it. My ucp isn't showing I sent it
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
