Topic: 87 Thunderbird Turbo Coupe ABS Wiring Removal (Read 1510 times) previous topic - next topic
Hello!
I have an 87 Turbo coupe that unfortunately has had the entire ABS wiring hacked and spliced all over the place.  What I'd like to do is remove as much of the ABS wiring as much as possible as I'm switching to a Vacuum based setup next weekend.
Sorry don't have any pictures, but it looks as though the owner before me decided to not use the 2 Relays directly to the right of the Teves unit on the firewall, and spliced in his own relays instead by cutting the wires and attaching spades to them.  Any good place to get a schematic to see what I may be able to remove from the car by chance?
Mainly I'd like to remove the: Anti-lock control valve block, anti-lock pressure switch and brake pressure switch if at all possible.
