Topic: Classique Cars Unlimited weatherstripping and hood blanket experiences? (Read 3621 times) previous topic - next topic
About to start restoring/restomodding my '83 and wonder if anyone has purchased the hood blanket, door weatherstripping, or window wipe kit from this company and how faithful they are to the original parts.
Thanks.
'83 302/AOD Heritage (silver/red, full restoration w/ SEFI, 5-lug, 8.8, rear discs in-progress)
'95 Explorer Limited (white/gray, 4x2, 323K mile daily driver)
'97 Cobra (black/black, bolt-ons, 4.10's)
'04 Lightning (black/gray, bolt-ons, stock-pulley gas guzzler)
I have not heard of them, but I need to find a better hood blanket too.
I'd be interested if anyone has found a good source to replace theirs.
I just got a new hood blanket from Class-Tech-Cars inc. Timberville,Va. Item# FOR_HIN_165. $62.95 with free shipping. The blanket fits perfect. (Hood insulation 83-88 T Bird) Herb
I forgot to give the #. Call  Chad White at Class- Tech 540-896-5758. Herb
Thanks for the info
Thanks for the info.  Will likely get my hood blanket from Class-Tech.
Probably going to bite the bullet and just order all the rubber from Steele, since it seems like they've got a pretty good reputation amongst the GM guys, their weatherstrip kit is a bit cheaper, and their dew wipes come attached to the molding already.  Searched for the vent window felt at JCWhitney, but the part number given in an earlier post (KM810358) doesn't seem to work anymore.
I looked at Steele's site and did not see where the dew wipes were attached to the molding.  Did you call and confirm this?  I need new ones but do not necessarily need them attached to the molding it is super easy to drill the rivits on mine and replace.  Makes me wonder if Classic is just not buying Steele's stuff and reselling.
Darren
It would be nice if Steele would offer the window run channels :( But it's great that you can now get just about everything else from them.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Quote from: Aerocoupe;425687
Darren
The jc Whitney ones are dead nuts, I'll have to look for the ones I used but are super cheap!
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
I thought you had to trim the dew wipes from JC Whitney?  I ordered two sets because of that and still have them in the box as I have not had time to mess with them.  I will most likely be offering them up for sale now that I know where I can get them ready to install.
Darren
Quote from: 347Thunder;426236
would you mind posting the part # for these,would be interested in getting some ?
That's the problem...JC Whitney constantly changes part numbers for everything. They DO have pretty much the correct window dew wipes for 1983-86 cars. I'm running them on the convertible with no issues whatsoever (minor tpuppies needed for vent windows). However, the part numbers that I used will not be what's available today...or tomorrow...
No they are thought you were looking 4 some
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I was doing a little research on the window run seal (KM 810358) which JC Whitney had carried. It turns out the new number is F1007 which is manufactured by Fairchild. It is listed for a Ranger with a vent window. I looked it up on the JC Whitney site as an 86 Ranger and right next to the new number is the old number(810358) used as an SKU number. I also found out from a Rep at Fairchild that JC Whitney was bought out by US Auto Parts. That explains the part number changes. I need these seals for my Bird also. They are $27 at JC Whitney and Rock Auto has them but they are $31 through them.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
93 Mustang LX 351C C4
2013 Honda CRV AWD
