Topic: Fuel Pump. . . (Read 4698 times) previous topic - next topic
Fuel Pump. . .
Me thinks my fuel pump is going. So here are the symptoms
1-Start car on first crank then dies. Turn the key on to run the pump a few times, car starts and stays running. I can hear the pump running and it even sounds different than it used to.
2-Hesitation, sputtering and backfiring under load. Coasting down hill, cruising on level ground, runs like a new car.
3-Faint whine coming from the tank once the car is running. Not really loud but it's there.
I'm looking at the BBK pumps but am unsure if I should go with the 155 or the 190. Any ideas?
For anyone who has installed one of these, are there any complications I should prepare for before I begin?
Thanks.
Re: Fuel Pump. . .
sounds like my luck is rubbing off
make sure you get a pump with the install kit, comes with the sock, the oring, clamps, small hose, wiring pigtail, and then go over to advance, and get the fuel line retainer clips, like for the fuel filter, i do believe there are 2 different ones though for the fuel lines
Re: Fuel Pump. . .
Pay attention to the ring that holds the pump on the tank.  Clean it off real good before you decide you "think" you know how it comes off.
The retainer ring on the tank needs to be rotated with a flat head or a punch so it lines up and lifts out.
the stock oring that seals your pump to the tank will need silicone that wont break down if gas makes contact with it.
You can buy a fuel pump for a Supercharged v6 cougar and come out cheaper.  they are about 95lph and will do fine.  total cost for my new pump was about 45bux.
empty your tank if you can using your old pump by grounding out the fuel pump wire up at the eec test hook up.
Re: Fuel Pump. . .
95lph is fine for a very mild build, but it all depends on how far he wants to go with the car, a 190lph would do great, seeing as Tom has had one in his car for years
Re: Fuel Pump. . .
Quote from: Tbird232ci
If that isn't the truth. I started the car and heard that stupid whine and thought where did I hear that before? :rolleyes:
Thanks for the input guys.
I think I'm leaning towards the 190 pump. I don't know how far I will be taking this thing but it's nice to know that if I decide to go all out, I don't have to worry about changing the pump again.
My current setup isn't all that radical. I wouldn't have problems using the 190 pump would I?
Don't want to go from starving the thing of gas with the bad pump to shoving too much down it's throat with a pump that flows too well.
Let me know if there's anything else.
Thanks.
Re: Fuel Pump. . .
Quote from: 5.0willgo
That's where your fuel pressure regulator comes into play. If you have an adjustable regulator you could fine tune your fuel pressure to best suit the engine.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
Re: Fuel Pump. . .
im running a 255lph high pressure pump with a stock regulator, and havnt had any problems, and youre probably putting down more power than i am
Re: Fuel Pump. . .
Quote from: slicksport88
Doh :brick:
Forgot about that for a second. Thanks.
Re: Fuel Pump. . .
Ok, maybe I'll start with just swapping the pump first and see how that goes before I spend more money for and adjustable FPR.
Re: Fuel Pump. . .
Yeah, I met Tbird232ci and now I have to fix my fuel tank leak, coincidence or a curse?  :giggle:
I did the jcassity thing and used the pump to empty the tank.  Now I have a lot of gas for the lawn mower!  Even after the pump sucked dry, there still was a gallon or two in the tank when I dropped it.
Heres a pic of the tank dropped.  My leak turned out to be the fuel gauge sensor (on left/drivers side) .. Man, look at how rusty the pump and sensor hangers became.  Couldn't leave it in that state.
Here is a pic of the stock sensor and pump.  I'm still looking for the sensor.  :disappoin
V6->V8HO 88 LS
5.0L V8 87 XR7
Re: Fuel Pump. . .
yeah,, see that float of yours?
my youngest son was deeply facinated with it. So curious he made out of the garage with it and up to his tree house.  I know he bent it cause when im on "E",,, im out of gas!!!!!!!!!!!!!
Re: Fuel Pump. . .
Quote from: bondocougar
That's right. We can blame all our fuel problems on Shawn :rollin:
Re: Fuel Pump. . .
what about nonfuel problems? :D
Re: Fuel Pump. . .
Quote from: Bane
Shawn...
Re: Fuel Pump. . .
Quote from: Bane
interesting,humm
could it be that all the things i do wrong infact are shawns fault,,
could it be that shawn made me do it ;)
could it be that shawn is the very reason i cant cut my grass this am cause its raining,, certainly  :giggle:
