Topic: Coil spring paint (Read 2015 times) previous topic - next topic
Coil spring paint
Anyone have luck painting coil springs & having it stick.  I assume the flexing is rough on enamel.
What paint did you use & how is it holding up?
Thanks
Coil spring paint
If you get springs from Oklahoma, they already look new and fresh. No painting needed. Even if they're 25 years old. Ask Jerry (Daminc).
Coil spring paint
Thanks Vinnie.  Mine aren't bad but they are out.  It seems I can't remove a part & re-install it without a fresh coat of paint.
Coil spring paint
A thin coat of paint whether it is enamel or urethane should be fine. Flex additives are needed for flexible plastic parts, but most paint will flex quite a bit without, you should be fine with using whatever you want on the springs as long as the film thickness is not excessive. How it holds up has more to do with the prep and correct primer than anything. If you are sand blasting, or cleaning  the springs to bare steel, I would etch prime them before painting for adhesion and rust protection.
Coil spring paint
Thanks.  I'll see if I can locate some urethane if not I'll stick with enamel .  Either way I'll keep the coats thin.
