Topic: Engine weight (Read 1069 times) previous topic - next topic
Engine weight
I was curious, how much does a 5.0 weigh vs. A 3.8? Specifically a tbi V8 vs a multi port V6. I magine the V6 is a lot lighter, fewer cylinders and aluminum heads.
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
Engine weight
I think the 5.0 with front dress weights about 500lbs. A 3.8 is probably about 100lbs lighter.
Engine weight
Oh ok. I was trying to figure out the power to weight ratio, sounds like a fox w/ a V8 would weigh about the same as a MN-12 w/ a N/A V6.
Engine weight
the lightest I've seen a mn-12 was 3800 lbs. I've weighed mine when it was empty (old 87, almost fully optioned 5.0) and it weighed 3400lbs or so.
Engine weight
I almost forgot, my buddies sister had a 94 xr7 4.6. it was about the same speed. we did a couple of freeway runs and who ever took off first won.
