Topic: In the market for an A9L EEC (Read 980 times) previous topic - next topic
Not technically a tbird part but I'm trying to turn SO into HO.
thanks!
Are you keeping the AOD or going with a stick? If you're keeping the AOD the A9P is a better choice.
Sticking for now with the AOD.  so I guess I need the A9P then.  Thank you for the correction.
