Topic: Getting a little mad here (Read 1577 times) previous topic - next topic
88 T-Bird.Performed the 5-Lug upgrade in hopes of better braking. Have not done the rear yet. Not a hole lot of added breaking power. Upgrade was done with 95 Stang parts. Decided to further the upgrade with drilled and slotted rotors, Lincoln Mark VII calipers and 95 Stang master cylinder. Current master cylinder I now find has 3 lines coming from it. The one from the Mustang only has 2. Bird one has third one going to the left front. ?????? Do I need distribution block and lines from the Stang? Lincoln calipers will not bolt on to the mounting brackets, and the ports for the lines are in a different location. Do I need Lincoln brackets? What about the brake hoses? Getting these upgrade ideas from Cool Cats site.
I now see I have gotten ahead of myself. Found the answers to the MC delima. Should not do that until I do the rear brakes. I have been waiting for a parts car for swapping the rear diff. That would be the time to do the rear disc conversion and replace the master cylinder with 3-2 conversion and adjustable prop valve. I will store the master cylinder for now and buy some rotors and calipers while I wait. Advance sells new brackets for the calipers. I will get some pr0nto along with some new hoses. I would think the Lincoln hoses would be appropriate. This should help with the poor braking for now and get rid of the terrible warped rotors. Have not felt comfortable with old calipers and hoses that have been sitting for years.
I find it hard to believe that people actually use thopse 3-2 line kits. When all that is needed is a trailer T and s flaring tool. But i guess it works.
That is most likely what I will do Tom. 3-2 conversion without the kit. Lots of info about this on the Mustang sites. Could be lots of info about it here, but I guess I was just a little to frantic to take the time and look. Don't like my bird to sit around in pieces!
No worry what i think you need is a master with a smaller bore size. We go through this all the time picking masters. You need something smaller than 1 inch to work correctly. Good luck
