Topic: Rear dif bushing ? (Read 1441 times) previous topic - next topic
Rear dif bushing ?
Hi everyone,
I am swapping the rear end in what I hope to become my DD soon with one from a parts cat I picked up that looks like it has been gone thru already. (big glob if rtv around the cover, bearings are tight & seals are dry...and it does have oil in it)
I want to replace the bushings and from what I gather the mustang kit should work.  Has anyone used this on a 87/88 bird ?
http://www.latemodelrestoration.com/item/PT-6302BL/79-93-Mustang-Prothane-Rear-Control-Arm-Bushing-Set-Oval-Bushing
I'm just trying to get back to stock status so I don't want/need any performance parts.
Is this reasonable price wise or am I overlooking a better deal,etc.
While I am asking does the 79-93 front/rear kit work on a 88 bird?  I'll need to deal with the front end also at some point soon.
Thanks thanks for the input.
Rear dif bushing ?
Yes and they work good. BUT!!! Some arms do not have OVAL BUSHINGS better check it!.
Rear dif bushing ?
Thakks Tom.  They are oval. I found them a little cheaper at summit & ordered some spring isolators also.
