Topic: Gas pedal assemblies??? (Read 1797 times) previous topic - next topic
Anyone know if theres a company out there that sells aftermarket gas pedal assemblies that fit using our stock mounting studs?
I know i can make an adapter plate, but if theres a whole unit available, it would be great!!
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
For a Bird or Cougar......good luck. You'll have to adapt something. Is the stock pedal no good or are you going with a new idea?
what exactly are you looking for?
our pedal clusters are compatable with any mustang pedal cluster. so anything for a 87-93 mustang will bolt right in.
I have one from a Fox Stang in the garage. Not much difference, just a slight difference in shape. Not enough that I'm swapping mine out.
 lol I was just hoping there were pedals out there that had different throttle cable attachments,ya know, like forlokar cables and stuff. Makes things a whole lot easier using an adjustable throttle cable when doing an engine swap.
what engine are you trying to swap that they don't already make a throttle cable for a mustang?
They make cables that will fit your pedal assembly. The cable hookup at the pedal is the same as a Fox Stang.
