Topic: TC rear springs and LX/base rear springs (Read 1372 times) previous topic - next topic
Does anyone know if there is a difference between the two?  The front ones are of course with the TC lighter motor.
Thanks
Yes they are different.  Different spring rates and height.
Mike
Excellent.  I assume higher rates and shorter for the TC.  thanks Mike.
Quote from: marianadeeps;422673
TC are shorter for sure.  Im not totally sure about the actual rate.
Mike
