Topic: 2003 Ford Escape brake light fuse..... (Read 3669 times) previous topic - next topic
Can somebody tell me where exactly it's located? I've looked on the interweb, and can't find it. I JUST ordered an owner's manual, but it would be nice to be able to find it asap. I wasn't sure where to post this since it wasn't Fox related. So, anybody?
CJB Central Junction box
Fuse F2.24  15 Amps
It is the LARGE fuse at the bottom of the ATC fuses on the left hand side . There are 2 big ones itis the one on the left
Thanks Tom. I had a good feeling you may know that answer. I'll give it a shot tomorrow morning and let you know if that was my problem. No brake lights, no signals, shifter interlock on the column isn't working and the hazard lights are not working.
I'm off to work. I'll check in later this evening when I get home around 8:00 tonight.
Good Luck My FRIEND. Hope this helped
I'll let you know in the morning. I JUST got home from work. Long day. Going to get a new fuse in the morning.
Tom, is that the fuse box under the hood?
I have to find the central junction box.
just for future reference:
bjb:battery junction box. under the hood next to the batt.
cjb:central junction box, should be up near the left kick panel somewhere.
and im currently looking for any tsb's or anything quick vin.
TSB's???
Tom, I found a diagram, and the two big fuses look to be F2.26 and F2.25. I want to make sure we're on the same page.
I can't seem to find a list of what each fuse does.
All data says 2.24 Hang tight i will pull it up again!!
Checked AGAIN it is an ATC fuse labeled pedal positioned brake. It should be the last fuse in the column. It has constant non keyed battery so it should not be hard to find it. Good luck!!
Check your owners manual!!
technical service bulletin's vin. what we use at the dealer.
cant get access today. forgot my password. UGH
Hopefully your smart junction box hasn't shiznit the bed... I've seen it happen in those Escapes
