Topic: 1988 cougar LS dasgh pad (Read 1131 times) previous topic - next topic
Have a 88 cougar LS that has a cracked dash pad-found a mint one in the junk yard. Question How do I remove dash pad and are there any special tools needed.
thanking all answers in advance..:D:dunno:
Check this link which is the procedure to replace the heater core, which requires removing the dash mounting hardware.
Whatever you do, DO NOT PRY THE SPEAKER GRILLS OUT. Bring a small piece of strong wire to fish inbetween the slots in the grill and pull up. If you pry at the grills along the edge, you'll crack your nice dash pad. Practice on your old one before going to pull the good one.
http://www.coolcats.net/help/heatercore.html
Rick
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
No special tools, but you will need a torx bit for a few screws.
Quote from: vinnietbird;421707
or a 7mm socket
