Topic: T-Stat Housing (Read 1564 times) previous topic - next topic
T-Stat Housing
Does anyone know where I can buy one?
Can't get mine to seal, I think it's warped
87 Turbo Coupe-2.3
T-Stat Housing
Does rockauto.com have them?
Mike
T-Stat Housing
I hate these stupid Chinese made cast iron thermostat housings!  I would find a good used off ebay or from someone on this forum before using another one of those P.O.S.
T-Stat Housing
lay it on a belt sander or just sand by hand using a wood block. too easy
you will start to see the low spots indicating worpage ( the un sanded areas)\
just keep sanding until the whole surface is scuffed then stop.
T-Stat Housing
Quote from: beast50;421801
One thing I found... I've got a 5.0L '88 XR7 and wanted to replace the thermostat housing... I got two from O'Reillys that were completely the wrong part... it didn't match at all.  Doublechecked the part, it was the correct number but the wrong part.  Ended up getting the right one at Autozone finally.
As always, be sure you check the part for correct fit before you get in a situation where it's difficult to swap it out.
Cabby
