Topic: TC 5 lug swap: where can I find 10" 5 lug rotors that work with stock calipers? (Read 2151 times) previous topic - next topic
Title nails it, I'm planning on getting a set of lincoln mark rotors for the front spindles which are I believe from a 93 stang, but yeah on the back I'm not sure where to look. I would rather not buy new calipers too as I'm getting all new rims, new axles, and 2 new tires for the front to help suck the sidewalls in, so yeah any ideas?
I can (but I don't want to) weld up one of the holes on my 4 lug rotors and redrill to 5 lug, but if I can buy a set of rotors that works I'd rather go that route.
Don't get the LSC rotors, not much selection of wheels, been there......done that :(  The problem that stems from them is the center hub is slightly larger and sticks out further as well. Just get a set of Ranger rotors. Someone will correct me if I'm wrong but I believe they are of the 10" diameter varity.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Email Tom Reid at Disc Brakes R Us. tom@discbrakesrus  They have five lug rotors  to fit the TC rear. They were $139 a pair when I inquired in Feburary.  I could never find them on their website, but Tom sent photos, dimensions and prices to me via email.
If you have a stock '87 or '88 TC disc brake rear, then just purchase a set of stock rear rotors from a 1991-92 Lincoln Mark VII.
One of 1,246 built
Cool, thanks guys! I'll probably go the lincoln route as I'd like to get the rotors asap so I can measure and make sure everything is gonna fit; the new rims I'm looking at have about 0.32" more backspacing than TC rims so I'm being real methodical atm.
I'd be careful with the lincoln fronts. The hub length and diameter limit wheel choice. Been there done that, but I've changed the front set-up. Good luck with it.
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
I used to run lincoln front spindles and rotors. My 16" eagle cobra R's fit but the 255-50-16 was scary close to the strut. My 17" svt cobra wheels and 275-40-17's required a significant spacer to clear, which put them into the fender lip on bumps. Didn't have issues with either on clearing the hub.
I swapped to 94-95 mustang spindles/hubs/brakes, and both sets of wheels clear perfectly.
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Are the any other better options for front rotors,.... Other than a SN95 swap?    Using 87+ Mustang spindles.
Mike
Quote from: 1BadBird;421501
Good thing for lathes huh? But,  it I hope it doesn't come to that.
What axles are you using to convert the TC rear to 5 lug?
1986 T-bird 3.8 *SOLD*
1990 Mustang
2004 Mach 1
