Re: Ford motor Sports Fuel Pump Warning?
Reply #11 –
Larger fuel pumps come into play also when you upgrade your fuel injector, so if you started with 14lbs ( which is what comes with a stock 5.0 bird) you only need to supply them with a 88 lph pump because the fuel demand is not that high. Now if I tried to run a 88lph pump to supply my 50lb injectors they would run the pump dry under full load.
