Topic: ISO t-5 fork and spacer (Read 1041 times) previous topic - next topic
need the clutch fork and spacer between eng-trans 5.8 t-5
also need 87-88 xr-7 buttstuffog cluster I have the tc one but I dnt  want the turbo gauge
I have the block plate pm me your zip and ill check shipping, make an offer on it
John
if you have a 351 bell then it will be a 164 tooth flywheel. the 94-04 v-6 should be a direct swap for the spacer. bell is similar for the v-6, but needs a longer input shaft.
