Topic: 88 Turbo Coupe - parting out (Read 6055 times) previous topic - next topic
I have a 1988 thunderbird turbo coupe that I am parting out.
* manual transmission car *
  It was a running car, when I pulled the engine to put in my Mustang project car.
I will part out anything..
Tell me what you want,  make an offer..  If both sides are happy, I will accept payment through PayPal, and send your part on its way..
I am an experienced EBay seller, so I know how to package things for safe shipping.
The only items missing from this car at this moment is the engine and associated sensors,  turbo charger, and CPU
Pm'd
Pm replied
can you get me a pic of the floor shifted bezel? I need one for my car. condition isn't super important as long as it doesn't look like complete .
Sure thing..
  The car is at my parents house, and I won't be able to make it out there until Friday.
I will get pics up on Friday.
Anything anyone wants, I will take special pictures of those items.
How about the interior? does it have the little door pull strap covers, in good shape?
Blue interior..  I believe the covers are all there
Pm sent
Ad your full location (City/State) to your ad or profile, please.
Quote from: Evilscout;421206
How much for all 4 sent to 27127
I could use the 5 speed console panel....you know, the one that goes around the shifter.
Pm'd
1987 Cougar XR7 308 S/C
Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
Lots and Lots of Parts to make you go FAST !!
2008 Mustang GT - - Dark candy Apple Red
Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
pm sent
I'm looking for the clutch fork.  Do you have it?
Can you give me a price for the drivers side power window regulator w/ motor if possible. Must be in perfect working order. Mine just failed.
I would be interested in the passenger side as well shipped to NJ
Thx
