Topic: Great replacement radiator option. (Read 1067 times) previous topic - next topic
After reading about radiator options for fox mustangs on corral, I decided to try the griffin universal 31x19. Its a tight fit, but dropped in my car on the stock mounts. I did have to bend the a/c condenser lines a bit, and work the hoses on as the connections are larger. Hard to argue with for the price though, and the mustang guys claim awesome cooling.
http://www.summitracing.com/parts/gri-1-26272-x
It doesn't have a trans cooler built in, but I've been using a large external for awhile now so it didn't bother me any.
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
For a griffin that's a steal of a price if you can make it fit
