Topic: explorer injectors in a fox fuel rail (Read 1855 times) previous topic - next topic
they fit perfectly!!!
thought you all would like to know the "hat" size is identical from what my naked eye can tell, the 96 injector (edit per post 5) pops right up in the hat and fits really snug.
Make sure those later injectors have same connector sockets for the foxbody injector harness.  They changed that in a newer generation of those Bosch injectors but they have adapters to pigtail them in.
I used that style for years in the SPort until I went to the Summit 24's.
the fox injector harness snaps right on these injectors
Uhh, did you mean 1996? All the explorer 5.0's (96-01) used 19lb injectors with the EV1 connector, will swap right into the fox rail. I'm using a set currently.
I'm pretty sure everything in 2006 is using EV6 connectors.
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Those injectors fit fine and same as the factory harness connector.  Just 4 hole pintle and supposedly atomize the fuel better.
Mike
Thats what I was referring to, I was unsure when they switched to the EV6 connector.  I have a set of the 96-01 EV1 19lbrs I am going to use in my Explorer intake upgrade; they came with the intake I just changed the screens, caps and orings.
i have to admit, the 96 injector screes are more forgiving in design than the previous screens i have *tossed out*.
they have less filtration than the 80's screens.
i dont use the injector screens personally.
