Topic: no low end (Read 1550 times) previous topic - next topic
no low end
well i finally made it to the track and was upset to run a 15.2 at 93 mph with a 2.6 60 ft. Of the line it seems as if I bogged until the r'shiznit about 3k then she pulled like she was supposed to. Is my stall too low for my engine upgrades. i have the b&m 2000. or is it due to a lack of backpressure due to me removing the all the cats and running true duals of each header never meeting. I think the exhaust is 2.25
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
Re: no low end
Dude, That 60 foot is dismal...... with a good launch I can't see why you wouldn't run a mid 14 second pass.  What was your launch technique?
Your exhaust is fine for your setup by the way.
Re: no low end
Quote from: Paul Flockhart
i tr it up to 2000 and launched. funny thing i didnt even spin tires so i dunno whats the deal.
                        :birdsmily:
Re: no low end
hmmm.....
Do you have a trak-lok in the rear and is it working properly?
What kind of tires/rims did you run?
What was your pressure?
How much gas was in the car?
How much stuff was in the trunk?
What kind of shape are your shocks in?
Re: no low end
If you are using street tires, you likely spun causing the bogish feeling(and the 2.6 60ft). On the race track the rubber on the line can fool you into thingking its not spinning. The mph is enough for a mid 14 with a good launch..
If it didn't spin, then you may have too much fuel pressure making the low end soggy.
Re: no low end
hmmm.....
trak loc went out.
17x9 cobra r's 255/40 17's
30 something
3/4 gas 93
nothin
stock since 88 not too bad
                        :birdsmily:
Re: no low end
Quote from: TurboCoupe50
yeah I see what your saying but i watched the mph nothin. its like I was towin a boat uphill or something.
                        :birdsmily:
