Topic: 88 t bird t c (Read 1553 times) previous topic - next topic
88 t bird t c
im having problems with my brakes hard brakes i bleed the rear lines just air came out pls help ty
88 t bird t c
First, do you have a constant abs and brake light on accompanied by a hard pedal? If you do your accumulator is shot.  Also, to bleed the brakes (rears) properly you must have a fully charged accumulator.
Stolen from SCCOA
Bleed the rears first.....
Top off the fluid in the reservoir....
Turn on ignition switch and let the brake system build up pressure....
Have your assistant apply the brakes while you bleed the RR, then the LR calipers.....
Turn off ignition.....
Top of the fluid in the reservoir.....
Bleed the RF, then the LF the conventional way....
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
88 t bird t c
If you end up needing the TEVES system, I'm converting mine to a regular booster and will be selling the TEVES, harness, and TEVES computer
86 Mustang GT
88 t bird t c
Quote from: Dougy_Fresh;420595
Dougy, if you end up parting that system out let me know. Between my 90 SC and my wife's 88 TC a spare accumulator is a beautiful thing.
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
