Topic: Stinger header (Read 1692 times) previous topic - next topic
Stinger header
Does anybody have any experience with the stinger center mount headers? I can't find a picture of the  to see if it is a D shape  like the ebay ones (Which from all other angles besides the angle that shows the , look like the stinger headers) or an oval  that perfectly matches up to the head.
Here is a D shape one that I see alot. http://www.xs-power.com/ford-turbo-manifolds-2.htm
Stinger header
The headers you posted are . Reason being no 2.3 exhaust manifold uses a GASKET!!! Or should i say any i use!!!
:popcorn:
Stinger header
I had one along time ago.  I dont recall it looking like a D shape like that, but as I said it was long ago and the design may have changed.
Mike
Stinger header
Quote from: TOM Renzo;420491
:popcorn:
I'm confused...
when I tore my 2.3 out of my TC, there was a gasket between the manifold and the head...
86 Mustang GT
Stinger header
Not from the factory!!
Stinger header
I used a cheapo gasket once...burned out...like Tom said...no gasket...some people have luck with abit of High-temp RTV....
Travis
Stinger header
Got a buddy with a svo and a ebay header kep blowing gaskets out and had cracks fixed more than one time
Finally just put the stock one on lol
Stinger header
Quote from: STANG8U;420665
Truer words were never spoken. 100% correct
