Topic: Mach 1 chin spoiler (Read 2087 times) previous topic - next topic
Mach 1 chin spoiler
What do you have to do to get a Mach 1 chin spoiler to fit on my 87 bird turbocoupe?
Mach 1 chin spoiler
Dry fit it. Pull the front wheels off first. Once you get it where you like it, screw it on, bolt it on, or make the push pins fit. You'll need to drill some holes either way. I used small bolts and washers. Then you'll need to cut the ends off. Otherwise, your tires will rub all over the spoiler ends. They extend a few inches too far.
Mach 1 chin spoiler
Okay that doesn't sound too tough. Thanks for the help Vinnie. I seems like am pretty much idolizing your car with the wheels as well.
Mach 1 chin spoiler
Oh btw, I see that there is a 94-98 option and a 99-04 option. Which one did you get?
Mach 1 chin spoiler
Not really sure. I just ordered a mach 1 spoiler and never looked back. I would bet they are about the same thing except for the mounting points may be different, which for our cars really doesn't matter since we are having to make the mounting points anyway.
