Topic: T-5 swap 1969 5.8 (Read 1782 times) previous topic - next topic
T-5 swap 1969 5.8
So after installing my 5 speed petals 6 years ago I finally got a t-5 z spec it came with a 4 puck clutch and billet fly wheel my engine is a 1969 351 w with a carb serp conversion using stock 5.0 balancer ill half to count the teeth on fly wheel and its got a changeable balance weight also (will the fly wheel work ?)got the adjustable cable and billet quadrant I need to get the following if any one can help
Clutch fork
Spacer between engine and trans
Has any one ever bought the clutches  off eBay there under $200
I need a throw out beating and pilot beating so I should replace the clutch  any way
I hope all this works I dropped $800 on this trans
T-5 swap 1969 5.8
Might be a better question for a mustang forum....the corral.net is OK....or Google search is always your friend.
Travis
T-5 swap 1969 5.8
351 should be 28oz imbalance, like the earlier 302's.
you should be able to get a 157 tooth flywheel and use the stock fox body style bell. the only difference might be ring gear offset, which is easily fixed by using a different starter  should be plug and play.
can't help you on the clutch though...
T-5 swap 1969 5.8
Yes you can get a 157 tooth 28 oz flywheel. That's what I have for my 351w swap. You should be able to change to the smaller weight for your flywheel to work with the balancer but the clutch seems a little extreme for the engine. That's where you will have to dig the rest of the info. I think you should just use a good single clutch and flywheel you know will work.
:burnout:
T-5 swap 1969 5.8
for what it's worth, a 70 mustang flywheel is 157 tooth, but you have to use a 10" clutch instead of 10.4/10.5
86 Mustang GT
