Topic: 460 Swap With stock K Member? (Read 10675 times) previous topic - next topic
Has anyone done a 460 swap and used the stock K member? If so how did it work out for you?
Quote from: ricktjr;419711
Might want to be a bit more specific about what year car, seeing as they weren't the same from 83-88.
1987 Cougar.
I sent these pics to Rick in a pm, but for future reference to those that search, I will offer my experience.
These are pics of solid mounts I made to fit the 460 in my 87 TC. n
One pic shows the upper half of the mounts on the 460 (on the cherry picker)
When I made them, I was using D5 exhaust manifolds.
In order to use my turbo headers, I had to use large nuts (as spacers) to raise the engine that amount, so that is what you see in the pics.
Putting the 460 in there is do-able with the 86-88 k-member, but you have to make your own mounts.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
I'm guessing the 460 won't fit under a stock hood with the spacers you added? I know you got it to fit before without the spacers but it was tight.
Quote from: thunderjet302;419988
Actually, even with the motor mount spacers and a 1/2 inch phonelic carb spacer, the 14 x 3 Moroso drop base air cleaner barely cleared the duct-work for the hood vents.
Yes, I am using 1/2 inch k-frame spacers as well as offset rack bushings for the manual steering rack. That's good for 1/2 inch.
Here are some pics of the install completed:
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Ah so it did still fit. I'm guessing sans K-member spacers it wouldn't fit under the hood?
Quote from: thunderjet302;420005
Correct, because the top of the spark plug wire boots on the dist. cap are now touching the plastic air scoop ductwork on the hood.
However, I have never took that scoop stuff off to see how much more clearance there is.
I left it on in case I get caught in the rain, then the water would just get the right side if the engine wet and not the distributor. (plus it looks better than without)
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Quote from: 83-88T-Bird Guy;420052
I wonder if a 460 would fit with a non Turbo Coupe hood and no K-member spacers?
I alwas thought this would look cool under the hood of a 4-eye Thunderbird
[ATTACH=CONFIG]32666[/ATTACH]
Quote from: thunderjet302;420064
I don't see any reason a 460 would not fit under a stock T-Bird hood. (without spacers)
My Gray 460 Bird does not have spacers and if I put the hood back down, I'm pretty sure the air cleaner will clear the hood.
Probably have to use a Moroso style drop down base air cleaner and a 14 x 3  filter.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Don't give me any ideas Lou :evilgrin: I might just have to do that but maybe with a 5spd behind it.
Sorry OP, not trying to hi-jack your thread
:bowdown:
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Alan, what headers are those?
86 Mustang GT
Quote from: Dougy_Fresh;420336
A company in southern California made those ( might still make them)
I believe they were called CPR.
Nice quality.
I think I kept their link on another computer.
Anyway, I bought them from a seller on fleabay years ago and had those mid-lengths jet hot coated after I modified them to fit the TC either way.
My plans at the time was to run twin turbos up front.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
I cant see how a 460 would fit without the spacer I had to cut out the hood bracing so my holly air filter would fit on top of my 302 with a 1inch carb spacer but I'm going the next step and getting a hood scoop for my car Saturday at the swap meet
What intake is that
