Topic: 1979 T-Bird w/no turn signals (Read 1593 times) previous topic - next topic
I am hoping that someone on here has the answer to this...
Just recently lost all turn signal functionality on my '79 T-Bird.  At first the right signal went out then the left one.  What is or isn't happening:
The interior turn signal indicators aren't lit nor is there any clicking sound indicating a turn.  Also there is no exterior indication for turns.  My initial though was a burned-out bulb somewhere, but I don't think that it would be a bulb since it took out the interior indicators AND the turn indicator sound.  My next guess is that it would be a fuse??  But I'm no ASE mechanic nor do I have the $$$ available to start "chasing" parts.
ANY ideas from the forum gurus??
check your fuses, if they are good then check your flashers with some known good ones. I also have a 79 thunderbird and will help you troubleshoot
Don't have any documentation for your car, but here some things to check:
Turn on the emergency flashers. Do all the bulbs work?
If the back-up lights don't work it probable is a fuse. Ford likes to put the back-up lights and turn signals on the same fuse.
But it can't hurt to check the fuses anyway.
You may have a bad turn signal flasher.
Sorry Turbo. your post wasn't there when I started typing and thinking.
I forgot that I have the EVTM for this car as well and I can scan the pages if you need it
That would be great 88turbo!
TYVM
Softtouch...
I did test the Hazard flashers and ALL of them are operational...
Might be the multi function switch in the column itself. Does your bird have tilt?
