Topic: Mystery Solved!!!! (Read 2061 times) previous topic - next topic
Mystery Solved!!!!
Well we finally got a signed work order on the GUTLESS MUSTANG 302. As i thought the cam was retarded a great amount indicated by the low compression readings across the board. Here is some photos
Note below the washer split in 2 and retarded the timing on the cam by 7*app. This is what i thought. The customer lied to me as the car was not 100* stock as he claimed. It has a cloyes adjustable cam gear, The washer split and it rolled back the cam timing as i mentioned before. This is a clear example of what i always say about aftermarket garbage parts. I will install a hardened pin that i ground to size with the  cam advance 6* to increase bottom end torque. Just wanted to post back on what i found on the NO POWER 302.
The damper was also changed to a PRO STREET UNIT of the proper counter balance as well. It never fails to amaze me that so many of these aftermarket parts are GARBAGE, Also expensive Garbage to BOOT!!! Thanks
Mystery Solved!!!!
you seriously get some really odd ball stuff landing in your lap!
sounds like my job actually,
Mystery Solved!!!!
I kind of had the same issue with my balance, took awhile to track down.
Mystery Solved!!!!
Yes i get all the dogs and then some. Have a great weekend GUYS!!
Mystery Solved!!!!
Good call
