Topic: T-5 swap parts list (Read 5490 times) previous topic - next topic
T-5 swap parts list
OK guys. I have a list of parts and I need to know if anything is missing.
1) WC T-5 with clutch fork
2) T-5 pedal assembly from a Mustang
3) Hurst short throw shifter
4) FMPP King Cobra clutch kit
5) FMPP Adjustable clutch cable kit
6) FMPP pilot bearing
7) FMPP 28oz 10 1/2" 157t flywheel (Engine is a 95 5.8L roller. I am running the stock truck balancer. I think that is a 28oz ballance.)
8) FMPP dowel kit for clutch pressure plate
9) Manual trans spacer plate (Between engine and T-5)
10) Polly transmission mount.
11) GM syncromesh fluid
Can you think of anything else I will need.
:burnout:
T-5 swap parts list
Oh, will I need longer flywheel bolts or will the auto trans flex plate bolts work? Ford says they are the same part number.
:burnout:
T-5 swap parts list
Idk if I would run syncro mesh in a t5. They use dex/merc ATF. Gear oil can make them grind gears. Change the input and output seals on the tranny if it is used. They are easy to change and guaranteed to leak if you don't. Other than that I would say, just make sure you get the flywheel, and pressure plate bolts.
T-5 swap parts list
The 5 speed wiring is also required when ya swap a Stang. I'm not sure if birds are the same
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
T-5 swap parts list
Yea use ATF ..... That gm shiznit is $10 a quart any way lol
T-5 swap parts list
I didn't need any harnesses to do mine. I just tied the wires together for the neutral safety switch. If you have a digital speedometer you will have to use the tbird speed sensor with the gear from the mustang speed sensor.
T-5 swap parts list
if you need a reverse light, you will at least need that connector.
T-5 swap parts list
I got the 5 speed connector. I am just wondering about the interlock switch. Is there not a harness taped up around the steering column area that can be used? Does it not need to see that signal? I was thinking of using that as a theft device and wire in a switch that will open the circuit. No mater if you step on the clutch, it will not start the car unless you pop the hood and jump the solenoid..... or find the switch and flip it.
I have a buttstuffog gauges in my car. This car is basically a turbo coupe with a 5.0L in it, minus the nose, hood, brakes and rear diff. But I swapped that all in.
I have a tonne of mercon 5 at work , or is there a synthetic oil I can use, maybe royal purple or something close?
Thanks for the info guys
:burnout:
T-5 swap parts list
Just for kicks and GIGGLES the GM fluid is superior and worth every penny. But if you feel inclined about mixing name plates FORD TYPE F COMES TO MIND!!!!
T-5 swap parts list
Quote from: 86caprirs;419570
just use atf. that's what the factory calls for. mercon should also be compatable.
your nss is not hooked up correctly. if I recall correctly it has a green connector. you need to run this line to the clutch switch to get it to function, or bypass it for now by jumping it. I think I cut the connector off and taped the wires up after soldering them.
T-5 swap parts list
Modern tranny fluids are to SLIPPERY for the T5. Type F is the ticket!!!
T-5 swap parts list
Haystack said : your nss is not hooked up correctly. if I recall correctly it has a green connector. you need to run this line to the clutch switch to get it to function, or bypass it for now by jumping it. I think I cut the connector off and taped the wires up after soldering them.
What do you mean its not hooked up correctly? I want it to function properly so I don't start it in gear accidentally or who ever borrows my car.
:burnout:
T-5 swap parts list
then you need to wire it up to the clutch. there are two connectors on the clutch itself. one is right above the clutch, the other is on the quadrant above the gas pedal.
on mine, the one above the clutch was broken, so I tried to set it up on the one above the quadrant and it worked the reverse of what I needed.
T-5 swap parts list
WOW for more years than i can remember stick cars would start with the clutch released. Now we are so used to modern  a NSS is necessary for the NOVICE. WHEEEEEEEEEEEEEE!!!!!!!!!! Wire it to the clutch pedal NSS. 2 wires not a brain teaser!!!!!!!!!!!
T-5 swap parts list
Pennzoil has a synchromesh that is waaay cheaper than the GM logo bottle from the dealer and most of the guys (myself included) run this in the Tremec TKO's.  I run Mobil 1 synthetic transmission oil my T-5's and have for over 15 years with great results.
Darren
