Topic: valve cover breathers (Read 1942 times) previous topic - next topic
Where can i find breathers that fit this style valve cover?  Look like it goes in and turns, I have only had push in before?
X
Its a breather cap with rubber cut outs and you push it in and twist it should be available at most mustang parts stores online.
Look up oil fill cap on Ebay.....hundreds
Advance auto parts sells them too
ok thanks for the info, I was getting worried they did not make that style anymore.
You can actually just buy the grommets also. They just pop in then you can use the push in style breathers too
