Topic: 5.0 Factory Air Box (Read 990 times) previous topic - next topic
5.0 Factory Air Box
PO of my car stuck a cone filter in the engine bay, so looking to fix that issue. I need the air box and lid, clips, and rubber mounting bolt thingies. I have converted to MAF, so I'm not sure if I can make the factory intake tube work.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
5.0 Factory Air Box
I have the tubes and box for MAF. I think I also have the rubber mounting bolt thingys as well.. I think it has the clamps as well. Send me $50 and I'll send you the setup. The box lid looks like it had a crack and was sealed up with some epoxy. No big deal. It's under the tube, and I didn't even notice it at first.
5.0 Factory Air Box
Ok, sounds good. Crack doesn't bother me as long as it is still structurally sound and can't pull non-filtered air. Could you verify that it has the clamps and mount bolts though?
Also, my MAF is a 70mm out of a 4.6l crown vic, not sure if that will work with the tubes. It should give me a good starting point though.
Thanks,
Chris
87 Thunderbird 5.0
TC 3.73 L/S rear
5.0 Factory Air Box
It should work fine. Mine is a stock piece that is using an aftermarket MAF. It appears to all be there.
5.0 Factory Air Box
Ok, I'll take it. PM sent.
87 Thunderbird 5.0
TC 3.73 L/S rear
5.0 Factory Air Box
Answered.
