Topic: TC vs 5.0 FPR (Read 1390 times) previous topic - next topic
TC vs 5.0 FPR
Simple question, Are they the same?
my TC has an adjustable fuel pressure regulator on it and I'd like to use it on a 5.0 if possible. mounting pad looks the same? Seems like I heard they work opposite each other
86 Mustang GT
TC vs 5.0 FPR
yup I have a 5.0 bbk reg on my 88
TC vs 5.0 FPR
Better watch the FUEL RAIL!!! IT WILL CRACK with an aftermarket regulator on a 2.3. I have a mod for this issue!!! Both engines have a 3 bolt mounting  and the valve is the same. BUT a turbo car uses a regulator that also works with vacuum as well as pressure.
Note a turbo car uses a RISING RATE REGULATOR an NA does not!!
TC vs 5.0 FPR
Tom is right I should have clarified...
Aftermarket adjustable fuel pressure regulator are the same for the 5.0/2.3T.
I have read that the fuel rails can crack...never had an issue...but what good 2.3T guy doesn't have spares... :-)
Travis
