Topic: New radiator time (Read 1041 times) previous topic - next topic
New radiator time
So my radiator is formed these white barriers over the inlets to let the coolant run through the radiator. So my car is overheating really fast. I was wondering if there is an aftermarket radiator that will bolt right up? any suggestions would help a lot. Thank you.
New radiator time
im planning on using a aluminum one for a fox mustang .....
New radiator time
I used a replacement on from autozone. a lot of the time you can hit a radiator shop and get yours recored for less.
new one was aluminium single core with metal tanks. none of that flimsy plastic . but it.does not fit in right into one of the hold down brackets.
New radiator time
I dont know of any radiator place in my area. But i'll check into the autozone and see what they have. thank you
New radiator time
call 1800radiator.
generally have free shipping,.and that's where the parts stores get theirs.
