Topic: 5.0 mystery trouble (Read 5036 times) previous topic - next topic
5.0 mystery trouble
Well from time to time people drop off their cars when it has been to several shops. That either threw parts at it or just were stumped. Here is what i found see if you can tell me where the issue is.
1995 5.0 HO 5 speeder with 373 in the tail
Car runs smooth and idles great
Timing 12* BTDC with spout out.
Injectors new and stock.
Plugs wires dizzy and all other tune up parts new. Including a new TFI and DIZZY
Fuel pressure at 43 PSI no vacuum and a brand new 225 Warlbro pump. Brand new fuel filter
Symptoms very boggy and absolutely no power
Cant break the tires loose in first gear by matting the pedal
Codes  181 and idle code 425. Idle below normal Cylinder balance perfect!!!
This car is the slowest stock 5.0 ihave ever driven
Thoughts on why gentlemen ????
Please post what you think is wrong. Then i will post what i found!!
5.0 mystery trouble
Are the cats still on it?  I bought a 3.8 cougar once that wouldn't spin gravel, ended up being plugged cats.
5.0 mystery trouble
Years ago I found a bad pcm that wouldn't advanced the timing on accel. Also found on another car  a crushed fuel line that would give good fuel pressure but on accel would drop off because of a fuel flow problem.
Donnie
10 Second NA TBird
Fredericksburg Va
5.0 mystery trouble
Ive heard of computer problems on them.  That would be my guess.
Mike
5.0 mystery trouble
Is code 425 ligit?
code 181-- adaptive learned fuel control maxed out due to a lean condition.
I second the crushed fuel line.
5.0 mystery trouble
Ok some more info. It is engine related. Even though this car is used every day by the customer to go to work. And it runs great other than a total lack of power. I can drive it a any speed i want and the kicker is it has absolutely no power. But it can be accelerated at any speed just no guts. You guys gave answers and fixes the other shops addressed in vain!!! Your answers were great. And i tested all of them in search of this loss of power. Once again ENGINE RELATED.
5.0 mystery trouble
Sounds like a plugged cat. My old 83 ad that same symptom. Would go anywhere at any speed just had no grunt. Knocked the cats out and she turned into a completely different animal
5.0 mystery trouble
Cats were checked. No back pressure whatsoever. They were changed out to high flow units by another shop in vein. Same trouble.
Remember i said it was ENGINE RELATED !!!
5.0 mystery trouble
Quote from: softtouch;417453
Is code 425 ligit?
SORRY typo Code is 415. Idle adaptive code. Glad you pointed that out Sorry
5.0 mystery trouble
Any customer mods to the motor and how many miles?
Darren
5.0 mystery trouble
even though you said the cyl balance was perfect,, that "could" mean they all were within reasonable tolerance of each other...
you didnt post compression numbers .........
so,,,,,
my best guess at this moment being remote like everyone else, the common denominator is the cam is worn too much but not enough to cause residual fuel to wick into the pan or on the 02 sensor.
5.0 mystery trouble
I was headed towards bad valve springs or an issue with the timing chain.
Darren
5.0 mystery trouble
yeah i was thinking timing distributor issue
5.0 mystery trouble
You say engine related, so that rules out fuel,air,ignition,exhaust. It cant be sensors, thats not directly engine related. Im guessing a very warn cam, not opening the valves far enough. The timing chain worn out and making the valvetrain sluggish. Or the timing chain being off a degree. Other than that ill admit that im stumped
5.0 mystery trouble
But he said it idles well, and smooth..
He also said it had 43 pounds with vac line off, so possibly rusted fuel rail is my contribution..
