Topic: Big fuel injectors (Read 2262 times) previous topic - next topic
Big fuel injectors
My spec clutch doesnt have many miles left before its broke in and I put my Stinger PIMP ECU in. I want to put 65lbs injectors in but I am not sure which brand to get. Stinger Doesnt sell 65lbs anymore more, so I dont know what to look for to make sure they fit properly even.
Any help would be greatly appreciated! Thank you
Big fuel injectors
I use a lot of FAST injectors in my engines. They work great on my LS builds. Hers is a source for the ones you are looking for. I think the PIMP can support these. If not call STINGER for specks. Hope this helps Thanks
http://www.summitracing.com/parts/fst-306504?seid=srese1&gclid=CLfiyaaw47cCFVOi4AodcSQARg
Big fuel injectors
Pimp can support Low and High impudence injectors....just have to move a jumper...
Travis
Big fuel injectors
I figured as much Travis the pimp from what i understand is very good. I am toying with the idea of getting one.
Big fuel injectors
If you're not sure, just buy a set from Stinger, even if they're a bit bigger. The ECU is programmable. The typical issue with larger injectors is trying to get a good idle quality. This was more an issue in the early days of the MS (and other aftermarket ECUs). These days with improved resolution and control, it's not a problem. Get some 80's or 85's and not worry about it. With your mods list, you might be limiting yourself with 65's anyway.
Big fuel injectors
Yeah Tom
Mine is installed but I havent used it yet.  Im about a year behind on my swap....but that is how it goes...life and such.
Shannon and his crew are very helpful...I have read lots of good things online...
I have 8  80lbs siemens deka injectors...high-Z
Travis
Big fuel injectors
OKay thank you guys for the help. I wasnt sure if injectors 75LBS and up would give me worse gas mileage and just not preform well. Stinger has yet to email me back even.
Big fuel injectors
I had 4. 75 injectors low-z. I bought from stinger in 2009.
Worked great with my LA3 and moates quarter horse.
Travis
Big fuel injectors
I have 60lb Siemens DEKA in mine. Piss easy to tune. Very good injectors :)
Big fuel injectors
What is your goal HP number??? If it is 400 you will need eighties. Other wise they might be a tad on the big side if HP is lower but workable to a point. Also what will your FP be. If it is 45 LBS?? Eighties are on the high side but workable at 80% and .6 @45 LBS
Big fuel injectors
Well Id like to run around 21-22 lbs of boost. Ive heard that these motors blow gaskets at around 24-25lbs. So I am not sure what horsepower i'll make with my mods at 22lbs of boost. I am not sure about fuel pressure. However I am looking at the 75lbs injectors from stinger. The stinger PIMP will do most of that tuning and for fine tuning, I am going to take it to a local dyno tuner that specializes in cars with power adders.
Big fuel injectors
Then the tuner should recommend the injectors. That is what you are paying him fore!!
