Topic: fan controller (Read 1427 times) previous topic - next topic
fan controller
anyone had this problem on their TC?  my fans quit working well they havent worked ever since I bought the car last year, just wondering if a parts store even has these.  I do know that Ford can still get them and they are pretty pricey around $130.  is there any way to test one of these?  thanks Graham
Re: fan controller
Quote from: 88turbo
http://www.turbotbird.com/techinfo/Cooling_Fan/CoolingFan.htm
mods: SDS DFI, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277,adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter,  Spec stage III clutch, Hallman boost controller, Weld Draglites with M/T ET Street 26x11.5/15
Re: fan controller
thank you. already checked these things,  almost positive that its the IRCM.  gonna change it on next payday
